Salesforce to JIRA Integration using REST
Mayur Gupta
January 2, 2015
I want to have integration between Salesforce to JIRA using REST webservice. On record creation in salesforce the issue should be created in JIRA. I have JIRA url, project and ISSUe type with me. I need Apex code and trigger to make it possible
MattS
January 2, 2015
There are several commercial add-ons that do this as well
Midori
January 2, 2015
Have you tried using Zapier for that? This, or IFTTT could save you some programming.
https://zapier.com/zapbook/jira/salesforce/
Alex Medved _ConfiForms_
Well, salesforce has a possibility to develop in JAVA, just make a HTTP REST call to your JIRA server... nice tutorial could be found here https://developer.atlassian.com/display/JIRADEV/JIRA+REST+APIs#JIRARESTAPIs-ASimpleExample:CreatinganIssueinJIRA
Nic Brough -Adaptavist-
January 2, 2015
What do you mean by "Apex code and trigger"?
You'll need to add something to Salesforce that can issue the calls to JIRA as per https://docs.atlassian.com/jira/REST/latest/ - for your case, I'd actually start with https://developer.atlassian.com/display/JIRADEV/JIRA+REST+API+Example+-+Create+Issue as you should be able to adapt that to whatever you write in Salesforce.
