Is there any possibility to enable a Gantt Chart for multiple projects? The idea is that the chart should display an overview of all the issues included in all projects. Many thanks!
You can use Gantt-Chart for JIRA by Frank Polscheit. It works fine with multiple projects, but has some problems with browser support.
This is precisely the plugin that we have installed. Unfortunately it doesn't seem to have an option to group issues from different projects into one chart.
Yes, if you enable the Gantt option "multiple projects" within the Gantt menu on the top right (cog icon), you will get displayed all issues you have selected by filter or board. If you have any further question, please send me a support request by clicking on the related menu item of menu named "?" within the Gantt-Chart at the top.
FYI
https://marketplace.atlassian.com/plugins/com.soyatec.jira.plugins.jira-ganttchart-project
http://www.jiraproject.com/confluence/display/JRAGANTT/User%27s+Guide
This filter is available if a gantt-chart contains issues from multiple projects. The availability and ruleof this option is listed in the following table:
Gantt-chart | Rule | Default Value | Description |
Time Plan Progress Tracking Reporter Tracking Sprint Plan | Data Input | Current Project | By default, it is mono project. Therefore, this option is hidden in general. |
Resource Plan Resource Tracking | Filter | All | Available |
Project Portfolio Portfolio Tracking | Data input | None | Available. |
