Is anyone aware of a script, plugin, or 3rd party tool that would scan the Atlassian database (and file attachments) for security risks like passwords, connection strings, and other secrets that someone may have inadvertently entered into JIRA and Confluence?
I've been looking for something similar myself, and this addon from the Marketplace, Nightfall, looks promising for cloud: Jira DLP: Cloud-Native Data Loss Prevention with Nightfall AI
Hi Joe,
Are you looking for an effective customized PII detector for JIRA and Confluence ?
Hello Scott,
What I am understanding is that you are look for a Data Leak Prevention (DLP) or Personal Identifiable Information (PII) plugin for Jira and/or Confluence.
The market place is a good place to start, searching for DLP turns up nothing. However searching for Personal Identifiable Information (PII) does yield results. Market Place Search Results.
An alternative would be to query the API for both Jira and Confluence and create your own search and filters. This would require a lot of lead time but would allow you to customize your searches and filters to you exact requirements. Here are the API documents for Jira and Confluence:
Jira REST APIs (server)
Confluence Server REST API (server)
I hope you find this helpful, let us know if you need further information.
-Stephen Sifers
Splendid! Thanks for your useful answer, Stephen!
Was this issue eventually resolved? I am also in a lookout for a Confluence solution that would search for specific words through spaces.
Hi Scott,
Hope you are doing good !
Are you still having trouble in detecting the PII data from JIRA & Confluence ?
Hi Jerome, im indeed still looking
Hi Felix,
Greetings !
Kindly note that we can able to support you. Can I have your email address to catch up with you ?
Thanks !
