I would like to know for the users of JIRA for the company, I would like to know if there is a feature, plugin, or way within JIRA bug tracking that part of the package that I have or a free plugin that can allow me to capture the screen without using print screen and saving to paint
Please let me know
Hi Sam,
Yes, JIRA allows to attach screenshots to issues:
image2015-6-7 22:35:6.png
This feature has been re-worked in JIRA 6.2.5 and works in mostly browsers: Safari is the only browser, which is not supported.
You can just:
image2015-6-7 22:40:59.png
If you are using JIRA 6.2.4 or older, the plug-in that supports this functionality in JIRA is available on Marketplace for free.
Atlassian also has a paid JIRA Add-on called JIRA Capture. It supports screenshot capturing, annotations, rapid issue reporting with attachments and adds test sessions functionality into JIRA. See this page for more information about JIRA Capture.
Hope this helps.
Ignat
JIRA Capture Developer at Atlassian.
Thanks so much Ignat for your help and guidance on screenshot within JIRA
I appreciate your assistance in this matter.
