I have a screen that pops up when transitioning from ready for review to closed.
The screen requires ticking before allowing me to close.
I would like to remove this option.
It seems you are mapping a screen to a workflow transition. In order to remove it, you need to identify the workflow and then click edit --> click on ready for review transition --> At the Edit Transition window, select None for screen then Save then publish the workflow.
