Script Runner - Clones an issue and links -> clone comments too
Peter Novak November 28, 2013
Hi there
Please can you help me, i want to clone all comments in this transition. How to do it? Some custom code? thx
RambanamP
November 28, 2013
you mean, need to copy the comments from parent to cloned issue then try with this code
CommentManager commentMgr = ComponentAccessor.getCommentManager();
Collection<Comment> comments = commentMgr.getComments(sourceIssue);
for (Comment comment : comments) {
	commentMgr.create(clonnedissue, comment.getAuthor(), comment.getBody(), comment.getGroupLevel(),comment.getRoleLevelId(), comment.getCreated(), false);
make sure you have updated source and linked issue objects as per requirement
hi
this works with Groovy runner? i am using Script workflow function "Clones an issue and links" and there i can fill Additional issue actions. Please can you help me how to configure parent and cloned issue?
scr
i can see there this option:
issueInputParameters.setComment('Write your comment here')
RambanamP
November 28, 2013
you have to replce the following objects
1. sourceIssue: it should be current issue object, i think you ca use as issue
2. clonnedissue: it should be clonned issue object, i am not sure how to get this
Hung Nguyen
Peter,
Not sure if you could finally do it? I want to do the same thing but could not find out how to make it work.
Hung Nguyen
This one doesn't work, even after I changed 'clonedissue' to 'issue' in the script Rambanam provided below. Error Null pointer assignment somewhere.
Peter Novak December 9, 2013
this question remains still open :(
