Script Runner - Create Sub-task conditional of Project
Jeanne Howe
November 10, 2015
We are using Script Runner to create sub-tasks on transition. How do we set up the post-function so that sub-tasks are only created for specific projects, and not for every project?
Example:
Project A transitions a Story to "accepted" and 3 sub-tasks are auto created
Project B transitions a Story to "accepted" and no sub-tasks are created
Nic Brough -Adaptavist-
November 10, 2015
You could use different scripts by having different workflows, or you could stick an "if" statement into the script to check which project you are currently in.
Jeanne Howe
November 11, 2015
Nic, I would like to add an "if" statement but can not find the syntax for getting the project name and/or id. The post function is run against the Accepted transition - issue.status.name == 'Accepted'
Jeremy Gaudet
November 11, 2015
I have a similar condition using the built-in script for creating subtasks on the Create transition, it's: issue.issueTypeObject.name == 'Story' && issue.getProjectObject().getKey() != ‘Project B' So, here, if it's a story and not Project B, the sub-task is created. I have two of these post functions defined, one per sub-task.
Davor Fisher
Jeremy, What do you mean by you have two of these post functions defined, one per sub-task? We are not having any luck using the script you gave us. Having no issues using issue.status.name script and sub-task are created, but need the ability to make sure it's only for projects that we have in the script, since there will be projects on the workflow that will not use this function. Thanks
Jeremy Gaudet
November 11, 2015
I mean my workflow's "Create" transition has two "Post Functions", both of which are of type "Script workflow function : Create a sub-task". Each of them has the criteria I listed above, replacing "Project B" with the one project I don't create sub-tasks for. For you, you'd need 3 post functions, unless you are creating them in a single custom script; at that point, my example condition will need to be integrated into your script as an explicit "if" statement.
Jeanne Howe
November 11, 2015
Thank you Jeremy! This worked perfectly - issue.issueTypeObject.name == 'Story' && issue.getProjectObject().getKey() != ‘Project B'
Davor Fisher
Jeremy, What if we had two or more projects that would be running the same script?
Jeremy Gaudet
November 12, 2015
Well, it depends on if you want to create subtasks for them or not. Say you have 4 projects, and you want subtasks for 3 out of 4, you use the same condition as above, where it's: issue.issueTypeObject.name == 'Story' && issue.getProjectObject().getKey() != ‘Project 4' If you only want subtasks for project 2, it's: issue.issueTypeObject.name == 'Story' && issue.getProjectObject().getKey() == ‘Project 2' And if you want subtasks for 1 and 4, you could use either: issue.issueTypeObject.name == 'Story' && issue.getProjectObject().getKey() != ‘Project 2' && issue.getProjectObject().getKey() != ‘Project 3' or: issue.issueTypeObject.name == 'Story' && (issue.getProjectObject().getKey() == ‘Project 1' || issue.getProjectObject().getKey() != ‘Project 4')
Davor Fisher
Thanks, it works great now! :)
