[Script Runner] Post function to set fixVersion and affectsVersion from CF
Błażej O_
June 9, 2014
Hello.
I'm trying to alter the code from the script runner documentation:
https://jamieechlin.atlassian.net/wiki/display/GRV/Post+Functions#PostFunctions-SetAffectsVersions,FixVersionsorComponents
I have done something like this:
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.web.action
import com.atlassian.jira.user
import com.atlassian.jira.project.version
import com.atlassian.core.ofbiz.CoreFactory
import webwork.dispatcher.ActionResult
import org.apache.log4j.Category
Category log = log
log.setLevel(org.apache.log4j.Level.DEBUG);
ComponentManager componentManager = ComponentManager.getInstance()
User remoteUser = componentManager.getJiraAuthenticationContext().getUser()
//MutableIssue issue = componentManager.getIssueManager().getIssueObject("DTT-1757")
MutableIssue issue = issue
def ver_affCF = customFieldManager.getCustomFieldObject('customfield_13302');//customfield containing string with affects version
def ver_aff = issue.getCustomFieldValue(ver_affCF);
def ver_fixCF = customFieldManager.getCustomFieldObject('customfield_13416');//customfield containing string with fix version
def ver_fix = issue.getCustomFieldValue(ver_fixCF);
Project project = issue.getProjectObject()
Version versionFX = componentManager.getVersionManager().getVersion(project.getId(), ver_fix)
Version versionAFCTS = componentManager.getVersionManager().getVersion(project.getId(), ver_aff)
//ProjectComponent component = componentManager.getProjectComponentManager().findByComponentName(project.getId(), "MyComponent")
issue.setFixVersions([versionFX])
issue.setAffectsVersions([versionAFCTS])
//issue.setComponents([component.getGenericValue()])
Map actionParams = EasyMap.build("issue", issue.getGenericValue(), "issueObject", issue, "remoteUser", remoteUser, "dispatchEvent", Boolean.FALSE);
ActionResult aResult = CoreFactory.getActionDispatcher().execute(ActionNames.ISSUE_UPDATE, actionParams);
// check aResult
However, even after adding import wich I think are correct (at least that's what I've found in https://docs.atlassian.com/jira/) I still get following errors:
2014-06-09 16:14:02,248 Thread-12981 ERROR bolszyca 973x252239x2 1bth0u4 10.1.3.34 /secure/CommentAssignIssue.jspa [onresolve.jira.groovy.GroovyRunner] The script failed : javax.script.ScriptException: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script4.groovy: 5: unable to resolve class com.atlassian.jira.web.action
 @ line 5, column 1.
Script4.groovy: 6: unable to resolve class com.atlassian.jira.user
 @ line 6, column 1.
Script4.groovy: 7: unable to resolve class com.atlassian.jira.project.version
 @ line 7, column 1.
Script4.groovy: 18: unable to resolve class User
 @ line 18, column 6.
Script4.groovy: 27: unable to resolve class Project
 @ line 27, column 9.
Script4.groovy: 28: unable to resolve class Version
 @ line 28, column 9.
   Version versionFX = componentManager.getVersionManager().getVersion(project.getId(), wersja_naprawa)
Script4.groovy: 29: unable to resolve class Version
 @ line 29, column 9.
   Version versionAFCTS = componentManager.getVersionManager().getVersion(project.getId(), wersja_znaleziono)
7 errors
2014-06-09 16:14:02,248 Thread-12981 ERROR bolszyca 973x252239x2 1bth0u4 10.1.3.34 /secure/CommentAssignIssue.jspa [onresolve.jira.groovy.GroovyFunctionPlugin] Script post-function failed on HOSP-3615: C:\Program Files\Atlassian\JIRA\atlassian-jira\skryptyistyle\update_versions_components.groovy
 @ line 5, column 1.
 @ line 6, column 1.
 @ line 7, column 1.
7 errors
	at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117)
	at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:103)
	at javax.script.AbstractScriptEngine.eval(Unknown Source)
	at com.onresolve.jira.groovy.GroovyRunner.runFile(GroovyRunner.java:102)
	at com.onresolve.jira.groovy.GroovyRunner.run(GroovyRunner.java:62)
	at com.onresolve.jira.groovy.GroovyFunctionPlugin.execute(GroovyFunctionPlugin.java:38)
	at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1050)
	at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1446)
	at com.opensymphony.workflow.AbstractWorkflow.doAction(AbstractWorkflow.java:564)
	at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowActionInsideTxn(OSWorkflowManager.java:954)
	at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowAction(OSWorkflowManager.java:909)
	at com.atlassian.jira.bc.issue.DefaultIssueService.transition(DefaultIssueService.java:450)
	at com.atlassian.jira.bc.issue.IssueService$transition.call(Unknown Source)
	at com.onresolve.jira.groovy.canned.utils.WorkflowUtils.actionIssue(WorkflowUtils.groovy:87)  <+2>
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90)
	at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233)
	at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite.invoke(StaticMetaMethodSite.java:43)
	at org.codehaus.groovy.runtime.callsite.StaticMetaMethodSite.call(StaticMetaMethodSite.java:88)
	at com.onresolve.jira.groovy.canned.workflow.postfunctions.FasttrackTransition.doTransition(FasttrackTransition.groovy:136)
	at com.onresolve.jira.groovy.canned.workflow.postfunctions.FasttrackTransition.this$2$doTransition(FasttrackTransition.groovy)  <+2>
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1054)
	at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.invokeMethodOnCurrentN(ScriptBytecodeAdapter.java:78)
	at com.onresolve.jira.groovy.canned.workflow.postfunctions.FasttrackTransition.this$dist$invoke$1(FasttrackTransition.groovy)
	at com.onresolve.jira.groovy.canned.workflow.postfunctions.FasttrackTransition$1.methodMissing(FasttrackTransition.groovy)  <+2>
	at groovy.lang.MetaClassImpl.invokeMissingMethod(MetaClassImpl.java:811)
	at groovy.lang.MetaClassImpl.invokePropertyOrMissing(MetaClassImpl.java:1103)
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1056)
	at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:884)
	at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66)
	at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:149)
	at com.onresolve.jira.groovy.canned.workflow.postfunctions.FasttrackTransition$1.run(FasttrackTransition.groovy:96)
	at java.lang.Thread.run(Unknown Source)
Caused by: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
 @ line 5, column 1.
 @ line 6, column 1.
 @ line 7, column 1.
7 errors
	at org.codehaus.groovy.control.ErrorCollector.failIfErrors(ErrorCollector.java:302)
	at org.codehaus.groovy.control.CompilationUnit.applyToSourceUnits(CompilationUnit.java:858)
	at org.codehaus.groovy.control.CompilationUnit.doPhaseOperation(CompilationUnit.java:548)
	at org.codehaus.groovy.control.CompilationUnit.compile(CompilationUnit.java:497)
	at groovy.lang.GroovyClassLoader.doParseClass(GroovyClassLoader.java:306)
	at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:287)
	at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:267)
	at groovy.lang.GroovyClassLoader.parseClass(GroovyClassLoader.java:214)
	at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.getScriptClass(GroovyScriptEngineImpl.java:337)
	at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:109)
	... 43 more
It seems like something is horribly wrong with imports. Unfortunately I'm out of ideas what may be wrong.
3 votes
Henning Tietgens
June 9, 2014
It's unlikely that an import ends with a lowercase word. Try this
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.version.Version
import com.atlassian.jira.project.version.VersionManager
Category log = log
CustomFieldManager customFieldManager = ComponentAccessor.customFieldManager
VersionManager versionManager = ComponentAccessor.versionManager
Version versionFX = versionManager.getVersion(project.getId(), ver_fix as String)
Version versionAFCTS = versionManager.getVersion(project.getId(), ver_aff as String)
issue.setAffectedVersions([versionAFCTS])
And place this postfunction at the beginning of the list of postfunctions.
JamieA
June 9, 2014
It is. And if you use "def" rather than the static typing you can get rid of most of the imports.
Błażej O_
June 9, 2014
Thanks, I'll remember that :)
You guys are awesome :)
JIRA_USER March 15, 2017
Hi Henning Tietgens,
thanks for providing the information.
However, after I implemented the code in Create Transition/postfunction, I was able to get the value in Fix Version/s which was on the basis of Custom field. But seeing two different issues. Would you please update those for me please?
1) When I go to the Edit screen, the Fix Version/s is Null (value is not available) but is available in View Screen.
Note: Both View and Edit screens has same Fix VErsion/s field.
2) Would it be possible to auto populate the value of Custom field (Release VErsion = 1.1) in Fix Version/s in a create screen (before creating a defect)?
Please help.
