Script Runner- built in script error
Sravan Kumar July 20, 2017
Hello Team,
I am getting an error while trying to use a built in script "Copy Project" in script runner.
The below is the error:
Error
E:\Applications\Program%20Files\Atlassian\JIRA\atlassian-jira\WEB-INF\classes\actions.xml (The system cannot find the path specified)
java.io.FileNotFoundException: E:\Applications\Program%20Files\Atlassian\JIRA\atlassian-jira\WEB-INF\classes\actions.xml (The system cannot find the path specified) at com.onresolve.scriptrunner.canned.jira.admin.CopyProject.doValidate(CopyProject.groovy:280)
Any ideas to what needs to be done to fix this?
TIA!!
Jenna Davis
July 20, 2017
What versions of ScriptRunner and JIRA are you using?
Jenna
Sravan Kumar July 21, 2017
Script Runner: 5.0.11
Jira: 7.3
Jenna Davis
July 21, 2017
I believe you're expiriencing this issue. A fix for the bug was relseased with version 5.0.14, so I would recommend updating your ScriptRunner version as soon as possible.
Let me know if you have any more questions!
Jenna
