×Hi, I have Epics and "normal" issues with custom fields that hold some numbers,
I want to add another custom field to the epic that shows a calculated value based on values from the epic and its linked issues.
I do know how to do the calculation, but I can't figure out how to get the list of linked (through epic link!) issues.
All I found was either using the normal issuelinks function or some old greenhopper code.
Any help with that?
In short, I need
-Get all tasks with epic-link = currentTask
-Get customFieldValue1 from these tasks
-Calculate against customFieldValue1 from currentTask
-Store result to customField2 in currentTask
You can use searchService class - https://developer.atlassian.com/static/javadoc/jira/latest/reference/com/atlassian/jira/bc/issue/search/SearchService.html
You can supply a JQL query as a parameter for the method - parseQuery(ApplicationUser searcher, String query)
Once you get the parseResult Object, you cna get the query() and invoke the method-
search(ApplicationUser searcher, Query query, PagerFilter pager)
This will return the issues which satisfy the original jql search query - "Epic Link" = "XYZ-123" thus you will now have list of issues with the epic link as the epic key and the epic itself.
And once you have all the issue objects then you can easily fetch the values of the fields and do the calculation whcih you want.
