Script Runner: get users not in jira-users group
Jeff Underwood August 27, 2012
I am trying to identify users not in the jira-users group. I have this script i found that gives me members of the jira users group but i'm not sure of the syntax to get only users not in the jira-users group. I also am trying to have this script send an email with the output of the script. I would appreciate being pointed to some resources that would help me with this. is there some documentation that shows this?
1. groovy script to show "non jira-users" members
import com.atlassian.jira.ComponentManager
def componentManager = ComponentManager.instance
componentManager.getUserUtil().getGroup("jira-users").getUsers()
Thank you.
Jobin Kuruvilla [Adaptavist]
August 27, 2012
You will have to get all users using getUsers method and use GroupManager to see if the user is in jira-users group or not.
http://docs.atlassian.com/jira/latest/com/atlassian/jira/security/groups/GroupManager.html#isUserInGroup%28java.lang.String,%20java.lang.String%29
to give credit where credit is due, I got this script from one of Jamie Echlin posts. Great script Jamie.
I will take a look at this option.
