Script Runner setting Assignee on Issue
Will C
May 30, 2018
Hi there,
I am looking at ways of setting the assignee on a workflow post function. Firstly I have been testing this out using the script runner console with the following piece of code that I seen Stephen Cheesley posted here
def issueService = ComponentAccessor.getIssueService()
def userManager = ComponentAccessor.getUserManager()
def user = userManager.getUserByName("tbas")
def issue = issueManager.getIssueObject("HW_TEST-64")
def validateAssignResult = issueService.validateAssign(user, issue.id, issue.reporterId)
issueService.assign(user, validateAssignResult)
However whenever I used this script in the console it sets the assignee to whoever the reporter is on that issue, no matter who I define it should be in the script.
Am I missing something obvious here?
Will C
February 17, 2020
came back to look at my old questions now I have been using Scriptrunner for a bit longer and have built up more experience.
The way to do this is the following:
import com.atlassian.jira.event.type.EventDispatchOption
def user = userManager.getUserByName("user")
def loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def assigneeUpdate = issue.setAssignee(user)
issueManager.updateIssue(loggedInUser, issue, EventDispatchOption.ISSUE_UPDATED, false)
Danyal Iqbal
May 30, 2018
validateAssign(ApplicationUser user, Long issueId, String assignee)
the reporter is set as id coz you explicitly set it to issue.reporterId.
use instead
def validateAssignResult = issueService.validateAssign(user, issue.id, user)
Will C
May 30, 2018
Thankyou! school boy error it seems.
Although I've tried running it with your suggestion but it still doesn't set the Assignee to the user I set in the script and there are no errors when I try to run it.
Will C
June 27, 2018
I am still looking at doing this, just to give some more background.
my end goal is that I can copy a project including some issues over to a new project - this is working fine.
Now I want to be able to change the assignee of the copied issues to somebody who I stipulate in the script or choose from a custom field.
I have got the copy project working from a workflow post function but now need to be able to change the assignee, I was thinking within the same script would be best? unless there are other methods I am not thinking of?
Will C
June 4, 2018
Thanks for all of the replies so far, I am still unable to change the assignee of an issue using scriptrunner console, any ideas?
Moses Thomas
see-above.
Moses Thomas
@Will C
You  may want to  do it this way base on a custom-field option-value(internal) on the  create issue screen in this case.
import com.atlassian.jira.issue.CustomFieldManager
CustomField cf86903 = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_86903")
String cf86903Value = issue.getCustomFieldValue(cf86903)
if(cf86903Value == 'Internal') issue.setAssigneeId("groovy_m")
