Script runner is incompatible with jira 8.0.0 and Jira servicedesk 4.0.0
Deleted user March 1, 2019
We upgraded our jira software v8.0.0. and Servicedesk 4.0.0 and found out scriptrunner is incompatible as below in UPM (Universal Plugin Manager). Its already latest version. I tried again clickin Update button and Enable button. Our all scripts are inside database, Can you please help how to update the script runner?
Dave Bosman [Realdolmen]
March 1, 2019
Hi @[deleted]
There is a version 5.4.49 and a version 5.4.49-jira8
You have the wrong one installed.
You can try removing the plugin, downloading the correct version, and installing it manually.
Here is the link of the file that you need on marketplace https://marketplace.atlassian.com/download/apps/6820/version/1001710
EDIT: If you don't trust downloading directly (and you should not trust it these time of days) you can find the file on this page. https://marketplace.atlassian.com/apps/6820/scriptrunner-for-jira/version-history
Just make sure you download the correct version
Br,
Dave
Dave, Thanks for quick response.
We have our built in script that we posted in workflows and behaviourous. if we uninstall and install new version will it be lost?
March 1, 2019
Normally all data will stay in JIRA but make a backup of both jira and the database, just in case something goes wrong.
