Script to add values of two custom fields
Deleted user November 2, 2016
Greetings, I have recently had two custom fields created:1. Impact/Risk 2. Effort/Cost which allow me to edit each of my stories  in my backlog view.
Each of these have a drop down menu and allow me to select, 1 of 4 options: None, 0  -Not Known, 1 - Low, 2 - Medium and 3 - High.  What is the best way to have another field representing the count of both of these fields, is there a script I can write that can add the values?
Any help would be much appreciated.
regards
Paul - Stephen
Vasiliy Zverev
November 3, 2016
Here is code for script field provided by ScriptRunner:
import com.atlassian.jira.issue.CustomFieldManager
int count = 0;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
switch((String) issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Impact/Risk"))){
    case "1 - Low":     count = 1;  break;
    case "2 - Medium":  count = 2;  break;
    case "3 - High":    count = 3;  break;
switch((String) issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Effort/Cost"))){
    case "1 - Low":     count += 1;  break;
    case "2 - Medium":  count += 2;  break;
    case "3 - High":    count += 3;  break;
return count;
