In post-functions part, I used 2 script workflow functions but I sometimes get this exception:
[atlassian.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 1041 from workflow 281049 on issue 'PRDIT-27342'
com.opensymphony.workflow.StoreException: Error marking step #642379 finished: root cause: Tried to update an entity that does not exist.
Any help would be greatly appreciated.
You need to make sure that the second one has a mutually exclusive condition to the first one. Only one of these should be allowed to execute.
Hi
I am also having this issue and I cannot find the problem.
There are no validations, only the std post functions.
[c.a.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 91 from workflow 725886 on issue 'CM-36372'
com.opensymphony.workflow.StoreException: Error marking step #2789074 finished: root cause: Tried to update an entity that does not exist.
2020-07-29 07:20:03,260+0200 http-nio-8080-exec-41 ERROR astrauss 440x192356x3 azj791 196.30.243.148,10.25.2.163 /secure/CommentAssignIssue.jspa [c.a.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 91 from workflow 726303 on issue 'CM-36387'com.opensymphony.workflow.StoreException: Error marking step #2789131 finished: root cause: Tried to update an entity that does not exist. 2020-07-29 07:26:20,725+0200 http-nio-8080-exec-25 ERROR astrauss 446x197000x1 azj791 196.30.243.148,10.25.2.163 /secure/CommentAssignIssue.jspa [c.a.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 91 from workflow 726296 on issue 'CM-36386'com.opensymphony.workflow.StoreException: Error marking step #2789150 finished: root cause: Tried to update an entity that does not exist. 2020-07-29 07:50:48,248+0200 http-nio-8080-exec-9 ERROR astrauss 470x219022x3 azj791 196.30.243.148,10.25.2.163 /secure/CommentAssignIssue.jspa [c.a.jira.workflow.OSWorkflowManager] Caught exception while attempting to perform action 91 from workflow 726315 on issue 'CM-36388'com.opensymphony.workflow.StoreException: Error marking step #2789452 finished: root cause: Tried to update an entity that does not exist.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE workflow SYSTEM "http://www.opensymphony.com/osworkflow/workflow_2_8.dtd" PUBLIC "-//OpenSymphony Group//DTD OSWorkflow 2.8//EN">
-<workflow>
<meta name="jira.description"/>
<meta name="jira.i18n.description"/>
<meta name="jira.update.author.key">suwebber1</meta>
<meta name="jira.updated.date">1593189027235</meta>
-<initial-actions>
-<action name="Create" view="fieldscreen" id="1">
<meta name="jira.fieldscreen.id">10212</meta>
-<validators>
-<validator name="" type="class">
<arg name="permission">Create Issue</arg>
<arg name="class.name">com.atlassian.jira.workflow.validator.PermissionValidator</arg>
</validator>
<arg name="conditionSelected">1</arg>
<arg name="includeTimeSelected">1</arg>
<arg name="date2Selected">created</arg>
<arg name="class.name">com.googlecode.jsu.workflow.validator.DateCompareValidator</arg>
<arg name="date1Selected">duedate</arg>
</validator>
<arg name="conditionSelected">2</arg>
<arg name="dateFieldSelected">customfield_10317</arg>
<arg name="expressionSelected">now</arg>
<arg name="class.name">com.googlecode.jsu.workflow.validator.DateExpressionCompareValidator</arg>
</validator>
<arg name="date2Selected">customfield_10317</arg>
<arg name="date1Selected">customfield_10318</arg>
</validator>
<arg name="fieldSelected">customfield_10326</arg>
<arg name="expressionSelected">^((\d{10})[,\s]{2})*(\d{10})$</arg>
<arg name="class.name">com.googlecode.jsu.workflow.validator.RegexpFieldValidator</arg>
</validator>
</validators>
-<results>
-<unconditional-result step="5" status="open" old-status="null">
-<post-functions>
-<function type="class">
<arg name="class.name">com.atlassian.jira.workflow.function.issue.IssueCreateFunction</arg>
</function>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowupdateissuestatus-function</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.UpdateIssueStatusFunction</arg>
</function>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.IssueReindexFunction</arg>
</function>
<arg name="eventTypeId">1</arg>
<arg name="class.name">com.atlassian.jira.workflow.function.event.FireIssueEventFunction</arg>
</function>
</post-functions>
</unconditional-result>
</results>
</action>
</initial-actions>
-<common-actions>
-<action name="Close" id="131">
<meta name="servicedesk.customer.transition.active">true</meta>
<meta name="jira.fieldscreen.id"/>
<meta name="servicedesk.customer.transition.resolution">10000</meta>
-<restrict-to>
-<conditions type="OR">
-<condition type="class">
<arg name="class.name">com.atlassian.jira.workflow.condition.AllowOnlyReporter</arg>
</condition>
<arg name="jira.projectrole.id">10200</arg>
<arg name="class.name">com.atlassian.jira.workflow.condition.InProjectRoleCondition</arg>
</condition>
</conditions>
</restrict-to>
-<results>
-<unconditional-result step="10" status="null" old-status="null">
-<post-functions>
</function>
<arg name="class.name">com.atlassian.jira.workflow.function.misc.CreateCommentFunction</arg>
</function>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.GenerateChangeHistoryFunction</arg>
</function>
</function>
<arg name="eventTypeId">13</arg>
</function>
</post-functions>
</results>
</action>
-<action name="Cancel" view="fieldscreen" id="141">
<meta name="jira.fieldscreen.id">10215</meta>
-<results>
-<unconditional-result step="12" status="null" old-status="null">
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</common-actions>
-<steps>
-<step name="Awaiting implementation" id="5">
<meta name="jira.status.id">10203</meta>
-<actions>
<common-action id="141"/>
-<action name="Start implementation" view="fieldscreen" id="71">
<meta name="jira.fieldscreen.id">10213</meta>
-<results>
-<unconditional-result step="7" status="null" old-status="null">
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
-<step name="Implementing" id="7">
<meta name="jira.status.id">10208</meta>
-<actions>
-<action name="Back to awaiting implementation" view="fieldscreen" id="81">
-<results>
-<unconditional-result step="5" status="null" old-status="null">
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
-<action name="Change completed" view="fieldscreen" id="91">
<meta name="jira.fieldscreen.id">14000</meta>
-<results>
-<unconditional-result step="8" status="null" old-status="null">
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
-<step name="Resolved" id="8">
<meta name="jira.status.id">5</meta>
-<actions>
-<action name="Back to implementing" view="fieldscreen" id="101">
<meta name="sd.resolution.clear"/>
-<restrict-to>
-<conditions>
<arg name="class.name">com.googlecode.jsu.workflow.condition.UserIsInAnyGroupsCondition</arg>
<arg name="hidGroupsList">mmicma@@</arg>
</condition>
</conditions>
</restrict-to>
-<results>
-<post-functions>
<arg name="field.name">resolution</arg>
<arg name="full.module.key">com.atlassian.jira.plugin.system.workflowupdate-issue-field-function</arg>
<arg name="field.value"/>
<arg name="class.name">com.atlassian.jira.workflow.function.issue.UpdateIssueFieldFunction</arg>
</function>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
-<action name="Close" id="211">
<meta name="servicedesk.customer.transition.resolution"/>
-<restrict-to>
</condition>
<arg name="hidRolesList">Change Request Approvers@@</arg>
<arg name="class.name">com.googlecode.jsu.workflow.condition.UserIsInAnyRolesCondition</arg>
</condition>
</conditions>
</restrict-to>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
-<step name="Closed" id="10">
<meta name="jira.permission.edit.group.1">mmicma</meta>
<meta name="jira.status.id">6</meta>
<meta name="jira.permission.edit.user.1">sbyrow</meta>
<meta name="jira.permission.edit.user.2">agovende</meta>
</step>
-<step name="Canceled" id="12">
<meta name="jira.status.id">10207</meta>
-<actions>
<common-action id="131"/>
</actions>
</step>
</steps>
</workflow>
Hi
I also have this issue, but I cannot find the problem : Below is my error and the workflow XML export. Please can someone help.
Workflow XML
-<workflow>
<meta name="jira.update.author.key">nzizi</meta>
-<initial-actions>
-<validators>
</validator>
</validator>
</validator>
</validator>
</validator>
</validators>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</initial-actions>
-<common-actions>
-<restrict-to>
</condition>
</condition>
</conditions>
</restrict-to>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</common-actions>
-<steps>
-<actions>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
-<actions>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
-<actions>
-<restrict-to>
-<conditions>
</condition>
</conditions>
</restrict-to>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
-<restrict-to>
</condition>
</condition>
</conditions>
</restrict-to>
-<results>
-<post-functions>
</function>
</function>
</function>
</function>
</function>
</post-functions>
</results>
</action>
</actions>
</step>
</step>
-<actions>
</actions>
</step>
</steps>
</workflow>
I would suggest you to to use two different transition and the second transition can be hidden transition ( part of workflow transition plugin) and make sure the second fast-track transition post-function is part of this second transition which is hidden from the user and can only be triggered from within the workflow itself.
Thank you for your reply Tarun. Both fast-track transition are hidden and so they are triggered from current transition itself.
I placed a mutually exclusive condition to the first one for the second one as per Jamie recommendation. It sometimes fails so I should wait if it works properly.
If both are hidden I would suggest you to put the second transition in the post-function of the first hidden transition , it's a much cleaner approach.
If you want to move issue through 2 transitions (as I understand from the screen) - it would be better to put one postfunction in current transition, and second postfunction to the next. THe behaviour of your current event is unpredictable, as you are not sure if the fire event after the transition was executed before the next try.
Thank you for your reply Alexey.
I have a condition for the first fast track transtion but not for the second one. So if the condition is not met than the second fast track transition is applied. However, it sometimes fails even if the condition is met and throws an exception that I mentioned in my post. Also the second fast track transition is applied.
And please tag your question with the plugin's tag.
You mean that I should write a mutually exclusive condition to the first one and I cannot blank it. Am I right?
@Jamie Echlin [Adaptavist] I placed a mutually exclusive condition to the first one for the second one as per your recommendation and it works now accurately. Thank you for your help. By the way, if you convert your comment to answer then I can accept it.
