[ScriptRunner]: Script scheduling problems using scriptRunner
Alessandro Concina
February 12, 2016
Hi
I'm configuirng a post function script to call a script on the machine in which is installed Jira using ScriptRunner. The groovy script calls the execution of the python script. Unfortunately the effective execution of the py script has a variable time. For instance with the issue xxx the script is called and runned immediately. By calling the script for the issue yyy (that is equal to the xxx issue) it takes more than 1 hour to call the Python script.
By looking a the postFunction groovy script it seems that all is ok (it's marked as correctly executed).
There exists a way for monitoring the execution or, are there known solutions related to this problem?
Thank you!
Mark McCormack (Adaptavist)
April 7, 2016
Alessandro,
I'm not aware of any existing problems but it also seems to me that you need to be thinking about using a monitoring tool on the machine or use more script logging in order to diagnose the problem further.
Alessandro Concina
April 10, 2016
Hi Mark
Thank you for your answer. It seems that there was a network issue not related to ScriptRunner. At the moment it looks working fine.
Goodbye
Alessandro
April 10, 2016
Good news - thanks for letting me know.
