I am trying to write post function that reset user's values (values passed by user to transition screen form). I also need to move those values to the subtask issue so i used 'Create a sub-task' script post function variant and pass this code to it:
import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.MutableIssue def i = transientVars.issue as MutableIssue def originali = transientVars.originalissueobject as Issue println originali.summary println i.summary i.summary = originali.summary
It works, but the problem is with issue history:
Issue summary before transition was '10'. During transition i passed '11' to summary field on sreeen. After transition execution i got this history entry:
The values are swapped. How to fix it ?
