I've created a filter on "ScriptRunner Enhanced Search" which is "issueFunction in linkedIssuesOf("project = TW and type = Epic and Status = Approved", "relates to")", if I use the tool "Browse and insert functions" it founds the issue I'm looking for, but once I click add to query the list is always empty.
Hey Octavian,
What issues are you trying to find?
If you are looking for all issues related to Epics that are approved replace "relates to" with "is Epic of".
Hope this helps,
Tyler
Hey Tyler,
I just found another way which is
"issueFunction in issuesInEpics("status = Approved")"
Thanks for the help.
