Scripted Field to return number of cloned issues not working
sharma-shweta September 24, 2013
My script to return the number of cloned issues not working as expected. it always returns 1.
Anyone know what the error might be? Also if I need to display the number of links that 'depend on' another link what do I replace the 'Cloners' with?
import com.atlassian.jira.issue.link.IssueLinkType
import com.atlassian.jira.issue.link.IssueLinkTypeManager
ComponentAccessor componentAccessor= ComponentAccessor.newInstance()
Collection<IssueLinkType> issueLinkTypes=componentAccessor.getComponentOfType(IssueLinkTypeManager.class).getIssueLinkTypes();
count = 0;
for (IssueLinkType linktype : issueLinkTypes) {
    String name=linktype.getName();
    if(name.equals("Cloners")){
        count++;
return count;
Hi, Thanks a lot. Finally got it working. :)
I was running it as a scripted field. I was messing up the Outward and Inward Links. I got it to work for 'depends on' like this:
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def issueLinks = issueLinkManager.getOutwardLinks(issue.id)
def subElements = issueLinks.findAll {
    it.getIssueLinkType().getName() == "Dependency"
return subElements.size()
Marie Goodart May 24, 2017
I get the error
groovy.lang.MissingPropertyException: No such property: issue for class: Script5
at Script5.run(Script5.groovy:4)
MichałS
September 24, 2013
import org.apache.log4j.Category
        it.getIssueLinkType().getName() == "Cloners"
subElements.size()
if you need to look for different link types just change the filter in the findAll closure to some other names (you can find them in Administration > System > Issue Features > Issue Linking).
For 'depends on' it would be probably
        it.getIssueLinkType().getName() == "depends on"
Best regards
MichałS
September 24, 2013
Do you run your code in a post function, custom JQL function, scripted field or what is the context? It may be that issue.id is null in your case.
You may look for InwardLinks, try this
def issueLinks = issueLinkManager.getInwardLinks(issue.id)
Hi, Thanks for the help.
I tried to run the code for "Cloners", but Im getting 0 as the output for both number of issueLinks and and subElements.size().
Do you know what might mbe the issue?
RambanamP
September 24, 2013
to get the issue link id's bi-directionally as follows
to get OUward links
List<IssueLink> allOutIssueLink = issueLinkManager.getOutwardLinks(sourceIssue.getId());
for (Iterator<IssueLink> outIterator = allOutIssueLink.iterator(); outIterator.hasNext();) {
    IssueLink issueLink = (IssueLink) outIterator.next();
    System.out.println(issueLink.getIssueLinkType().getId());
same way to get inword issueLink's
List<IssueLink> allInIssueLink = issueLinkManager.getInwardLinks(sourceIssue.getId());
for (Iterator<IssueLink> inIterator = allInIssueLink.iterator(); inIterator.hasNext();) {
    IssueLink issueLink = (IssueLink) inIterator.next();
	if (issueLink.getIssueLinkType().getId() == 10) {
	  Issue destinationIssue = issueLink.getDestinationObject();
check this
https://developer.atlassian.com/static/javadoc/jira/5.0.5/reference/com/atlassian/jira/issue/link/IssueLinkManager.html#getIssueLinks%2528java.lang.Long%2529
Hi, Thanks for your ans.
I tried to run the code but Im getting this error:
javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: issueLinkManager for class: Script21
Do you know what might be the issue?
RambanamP
September 24, 2013
you have to get issuelinkmanager as follows
IssueLinkManager issueLinkManager = ComponentAccessor.getIssueLinkManager();
Yes I need to get the number of cloned issues. (by counting the number of cloned issue links).
Do you how I could edit my code to achieve that ?
MichałS
September 24, 2013
Your script displays just the link types configured in the system. Thats why it is always 1.
But I suppose that you would like to display the number of clone issues connected to a given issue?
