×Hello,
I'm using the ScriptRunner plugin and using the post function "Clones an issue and links".
I have three projects - Project A, B and C. When i create a ticket in Project A, based on the custom field value it should create an issue in either Project B or Project C.
So for this, I'm using condition as -
cfValues['Security Component'] == 'Tenable'
I think your condition is wrong.
What is the type of Security Component Field ?
If it's a select list it should be:
cfValues['Security Component']?.value == 'Tenable'
Oh, that's my bad! Thank you so much. It worked.
