×> Because the JQL functions related to Agile only work for the 6.7.7 and above and that is also true of Copy Project That's true but this is a bug in the case of CopyProject... it should just not offer to copy the board if the version of JA is too low: please watch https://jamieechlin.atlassian.net/projects/GRV/issues/GRV-828.
Hi Cristian, I suppose the same questions apply to you as well. Which versions of JIRA Agile you use ? Because the JQL functions related to Agile only work for the 6.7.7 and above and that is also true of Copy Project.
Same problem here. Using JIRA 7 that includes Agile. When Checking with Firebug it shows an error: "NetworkError: 500 Internal Server Error - http://10.131.94.17/jira/rest/scriptrunner/latest/canned/com.onresolve.scriptrunner.canned.jira.admin.CopyProject/params"; Checking this link directly I get this error: HTTP Status 405 - Method Not Allowed type Status report message Method Not Allowed description The specified HTTP method is not allowed for the requested resource.
Hi Monica, I can see from your tags you use jira agile, can I ask you which version and if you use copy project to copy agile boards ? It would help a lot if you could paste any log errors and of course the script runner version you use.
