Can we use scripting (postman or scriptrunner)to remove users from Project roles(leaving only groups)
I have made a script that removes a group from a project role on all projects in an instance:
import com.atlassian.crowd.embedded.api.Group
import com.atlassian.jira.bc.projectroles.ProjectRoleService
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.security.roles.ProjectRoleActor
import com.atlassian.jira.security.roles.ProjectRoleActors
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.security.roles.RoleActor
import com.onresolve.scriptrunner.parameters.annotation.ProjectPicker
import com.onresolve.scriptrunner.parameters.annotation.ProjectRolePicker
import com.onresolve.scriptrunner.parameters.annotation.GroupPicker
import com.onresolve.scriptrunner.parameters.annotation.*
import org.apache.log4j.Level
import org.apache.log4j.Logger
import static com.atlassian.jira.security.roles.ProjectRoleActor.GROUP_ROLE_ACTOR_TYPE
import static java.util.Collections.singletonList
def log = Logger.getLogger("be.script")
log.setLevel(Level.INFO)
@GroupPicker(label = 'Group', description = 'Pick a group to remove from role', placeholder = 'Pick a group')
Group INPUT_group
@ShortTextInput(label = "Project role", description = "")
String INPUT_projectRole
ProjectManager projectManager = ComponentAccessor.getProjectManager()
ProjectRoleService projectRoleService = ComponentAccessor.getOSGiComponentInstanceOfType(ProjectRoleService.class)
ProjectRoleManager projectRoleManager = ComponentAccessor.getOSGiComponentInstanceOfType(ProjectRoleManager.class)
int count = 0
ProjectRole projectRole = projectRoleManager.getProjectRole(INPUT_projectRole)
List<Project> allProjects = projectManager.getProjects()
for (Project currentProject: allProjects) {
ProjectRoleActors projectRoleActors = projectRoleService.getProjectRoleActors(projectRole, currentProject, null)
Optional<RoleActor> actorToRemove = projectRoleActors.getRoleActors().stream()
.filter {it -> it.parameter.equalsIgnoreCase(INPUT_group.getName())}
.findFirst()
if (actorToRemove.isPresent()) {
count ++
projectRoleService.removeActorsFromProjectRole(singletonList(INPUT_group.getName()), projectRole, currentProject, GROUP_ROLE_ACTOR_TYPE, null)
log.info("$count => project $currentProject")
return "Done!"
With some tinkering you might be able to transform it so it removes a user form a project role in all projects or to whatever need you might have.
In the top of the script you will see the following:
Group INPUT_group
In the script runner script console this shows a dropdown to pick a group and an input textbox to provide the project role. You can replace this with logic for a hardcoded user etc ...
Near the end you will see this line:
The param GROUP_ROLE_ACTOR_TYPE tells the service to remove groups provided in the other params. This params can also be USER_ROLE_ACTOR_TYPE, which will indicate to remove users provided.
With this you should come to a solution.
Jeroen
Can we remove only users from project roles and we don't want to remove groups from project roles?
