Searching Custom Field Help
Beth Schaefer September 29, 2020
Is it possible to search all your a specific custom field the way you can easily turn on and off labels?
I have set up a custom field called "Issues" and I provided a drop down list of common issues. I would like to easily search all tickets that have a given selected issue.
Is that possible? How would you suggest going about this?
Trudy Claspill
Hello @Beth Schaefer
Welcome to the Community.
You should be able to search for issues with a specific value in the Issues field just as you would search any other drop down list:
Issues = <yourValue>
FREE
