Searching for Closed Jira Issues
Kathleen Veach
August 10, 2022
How can I find old Jira issues from previous sprints?
3 accepted
Lucas Modzelewski _Lumo_
Hi @Kathleen Veach ,
Welcome to the Atlassian Community
Here is a great and detailed article how to find issues from sprints with JQL, it's for Cloud but the idea is the same: https://community.atlassian.com/t5/Jira-articles/Common-JQL-queries-for-sprints-in-Jira-Cloud/ba-p/1736456
Sam Nadarajan
Hello @Kathleen Veach , and welcome to the Community!
It sounds like you'll want to use the Advanced Issue Search/JQL to find those issues.
In Jira, go to the Issues dropdown in the navigation bar, then select "Advanced Issue Search", then type out your query. You can start by typing "Sprint = XXXX" in the JQL view:
You can learn more about JQL here
Hope this helps!
Summer Hogan
Hi @Kathleen Veach - welcome to the community!
JQL is a valuable tool if you want run complicated queries. Excellent advice @Lucas Modzelewski _Lumo_ and @Sam Nadarajan
