Sections mixing up when using Color Custom Fields.
Adam Piotrowicz April 21, 2014
I have in my Jira one color custom filed with "none" and "Red" values. When particular users do particular actions workflow post finctions set the value of this field to "Red". This works great, but when the page is reloaded either with some action or manually then "People" and "Dates" sections moves below "Activity" one ...
Anyone saw this?
Andrey Markelov
July 22, 2014
Hello again, I have check for me works fine. Maybe there was conflict with your other custom plugins. But I am not sure.
Adam Piotrowicz July 22, 2014
Righh, maybe. I will try to confirm once possible.
Thank you for your support.
Andrey Markelov
July 20, 2014
Okey. Will try both
Andrey Markelov
July 20, 2014
Adam,
Please, provide which Jira version do you use? I will try locally
Adam Piotrowicz July 20, 2014
We tried it when we were on v5 (sorry, I won't be able to find exact one, but we can assume it was the newest one from v5 branch ~April). Now we're on 6.2.7, but had no chance to try it ...
Andrey Markelov
July 20, 2014
Hi Adam, could you provide more details, please?
Andrey,
I'm sorry but as we're launching our system in a week we had to give up using your awesome plugin as we were not able to figure out why this is happening.
Also because of that I'm unable to provide you with any screenshots - I can only repeat the description from above: when the workflow post function changes the value of my color custom field from "none" to "Red", then entire "Dates" and "People" sections (that used to be in right column) are moved below "Comments" section. In other words the layout of Jira is changing to one-column.
