Security level for Worklog in JIRA
jan.dolezal September 13, 2012
i browsed some sites and i am really confused if is possible in new JIRA 5.1.2 to set Security level for Worklog field ?
I want customer to not see worklogs, but only developers.
Is this possible ? If not, are you using some workarounds ?
Jobin Kuruvilla [Adaptavist]
September 13, 2012
Field level security is not possible by defaut in JIRA. There are no workarounds as well (excpe may be hiding it using Javascript!).
Try the Field Security plugin (commercial) or customize the view-issue bundled plugin to add some conditions.
Ok, thank you.
