×Hi for some reasons I can see epic links from the projects I'm not currently on. How can I avoid this?
Hi @Leo Li ,
Welcome to the community.
I think you are referring to the epic link field, right?
As you can link stories to epics from other projects, I don't think there is a way to avoid this, as it works as designed.
Hi Leo,
where are you referring to?
Which screen are you looking at?
im referring to "epic link" field. there are tons epic being created from other projects and I dont really want to see the epic issue selection from other projects. its really hard to select the right one.
