Seeing two same statuses
Stuti Gupta August 23, 2024
I am seeing two same transitions (Deployed to Production) in the options for changing the status
Image-JIRA.png?
3 votes
Shreeja J
August 23, 2024
Hello @Stuti Gupta
It looks like there are two identical "Deployed to Production" transitions.
You might want to check the workflow settings and remove the duplicate transition.
If you need help with this, just let me know.
Shreeja J
Thanks. It worked. I disabled "the allow this status to transition from all" check mark
