When a jira ticket is created then automatically a servicenow ticket should be created.
Using automation rule : Send web request component
can someone help me on this.
Hi Katta.
I would advise you to read this article by Cristiano from the Atlassian team.
I believe that if you need help configuring the automation rule from the ground and setting up service now to receive the call. I think you are best of with reaching out to a solution partner.
