Hi All,
Has anyone integrated Jira and Zabbix via an Automation rule to do the following:
- When an Jira Issue is created, an automation rule fires to send the summary of the newly created issue to Zabbix
Appreciate any pointers on how to achieve the above.
Thank you
Vish
Hello @Vish Reddy {Revyz} ,
Thank you for reaching out on the Atlassian Community.
While I personally have not seen any Cloud Users running Zabbix, that does not mean your goal is not possible.
I jumped directly into our Atlassian Marketplace and found that Zabbix did indeed have an Atlassian Marketplace page, although this was for Jira Server only:
https://marketplace.atlassian.com/apps/1215171/zabbix-plugin?tab=overview&hosting=server
While we do not directly have a Zabbix marketplace equivalent for Jira Cloud, you may be able to accomplish your goal using the Automation 'Send Web Request' action, so long as you can put together an HTTP request which can be processed by your receiving application.
