Sending mail for Subscription does not work for personal subscription
Richard Hierro May 30, 2012
Hi
I made several issues filters. And I made some subscriptions to those filters.
When the subscription is sent to a role (by example jira-developpers), it works, each developer receives a mail with the tasks of the filter.
But the personal subscription does not work, I do not receive mail.
And in the mais, links are incorrest:
TPSS-1 Install, 2eme journée
http://localhost:8083/browse/TPSS-1
instead of http://doc-server:8083/browse/TPSS-1
Thanks your for your help
Richard
I got a answer from Gan (Atlassian support) :
It look like you doesn't have the Base Url configure properly. Can you double check your instance base URL by refer to page below:
* https://confluence.atlassian.com/display/JIRAKB/JIRA+Notifications+Reference+the+Localhost+URL
It resolves the link problem (localhost instead of doc-server). But the personal subscriptions still do not work (no mails), and we receive mails with the role subscription.
