Set Resolution (system field) to Done when an issue is closed
Lori Milam
I have 2000+ issues that don't have a resolution but the status is closed. The reason is because there is no post function to set the resolution to done on the Close transition. I can't find a way through bulk edit or automation to set this system field. How can I do this???
Matthias Gaiser _K15t_
Hi @Lori Milam
what you could do is to add a temporary looped transition to your workflow from a state to itself. You can restrict this transition with a condition so that only you can see it and add a post function which sets the resolution to Done.
In a bulk change you can then apply this transition to all your issues.
And afterwards remove the transition.
Would this work?
Matthias.
Lori Milam
I tried this on a test project and it worked great! Thank you.
Like Matthias Gaiser _K15t_ likes this
