Set issue's read permission only to reporter
François-Xavier Choinière October 27, 2013
I've create a workflow with a "draft" state. When a reporter set his issue to "Draft" I want to make the issue readable, searchable et editable only by the reporter.
Is it possible?
In a post function, there's no option to change the level's security level. Why?
Bhushan Nagaraj
October 27, 2013
Hey efficks, you can do this using script runner or a simple post-function plugin. Are you using on-demand? or download?
Bhushan Nagaraj
October 27, 2013
Make it editable only by the reporter? Yes using workflow properties.
Make it not readable, not searchable and not editable? Using issue security
https://confluence.atlassian.com/display/JIRA/Configuring+Issue-level+Security
When you move the issue into the Draft state, use a post-function to set its issue security level. When you move it out, change the security level using the post-function.
