Setting Automation in Smart Checklist
Melanie Plourde April 4, 2023
I'm attempting to create a Smart Checklist item that is based on the due date of the issue created.
The use case is that we could use this to confirm when items are completed by the set timing (so somewhat incorporating a process item into the checklist format).
I was thinking I could use smart values to create something like the following:
- Task A completed by {{issue.duedate.minusBusinessDays(8)}}
I'm no coder, and that's likely clear to anyone that is, so bear with me as I explore automation options. Any help is appreciated!
Olena Brazhko_TitanApps_
April 10, 2023
Hi @Melanie Plourde
The Smart Checklist team researched your request and we can offer a solution via Jira Automation.
So, basically, you need to set an Automation Rule with three steps:
1. When: Issue created
2. Then: Set Issue property (please see below how to fill out the fields)
3. Issue fields condition (Due date, is not empty)
If you like to see this in a screen recording with detailed steps, please reach out to us at smartchecklist@railsware.com.
I hope this helps!
Olena
Olha Yevdokymova_SaaSJet
Hi @Melanie Plourde
Based on what you've shared, it seems that having clear visibility into the date when the checklist was submitted is crucial for monitoring the execution of the checklist. Additionally, it's important for you to have access to a no-code tool that can help you achieve this.
I would like to suggest using the Recurring Checklist and Reports add-on, which may help with your needs. With this add-on, you can create checklists in two ways - the first is to create recurring task with a checklist inside, and the second way is to add a checklist to an already created task with one click.
After somebody have submitted checklist , you will see a comment in the issue with the time when the form was completed, so the due date and the checklist submission date are in one issue to monitor these indicators.
With the ability to reporting in this add-on, you can also check report for the submission dates of all your employees and information from the checklist in one place.
I hope this helps and let me know if you need further assistance!
Bill Sheboy
April 4, 2023
Hi @Melanie Plourde -- Welcome to the Atlassian Community!
What part are you looking for help with:
  • creating automation to add the checklist item
  • the smart value for the date adjustment from Due Date
  • something else?
If you already have a rule and it is not working as you expect, please post images of the complete rule and audit log details showing the execution.  Those may provide context for what is happening.  Thanks!
