Setting Jira with nginx
Valeriy Orlov January 7, 2012
We have installed apache (as back-end) with ngnix (as front-end). The site opened, but not displayed style. How to adjust the jira with nginx?
FinalX August 17, 2012
I had the same problem, and after an hour of searching around, I finally figured it out; I had changed the username nginx ran as, and nginx had already made some directories on the filesystem to store the cached proxy files in.
Do a chown over the dir that holds the proxied content, like, for example on Debian 6.0:
chown -R newuser /var/lib/nginx/proxy/*
I actually had the problem with Confluence, but I'm sure it's the same for anything proxied.
Another issue I had with JIRA was the dashboard being pretty empty, try adding this in that case (given that you've set it to BLOCK elsewhere):
add_header  X-Frame-Options ALLOW;
JIRA (and only JIRA of the products I use) needs this.
Anatoly Mikhaylov
February 3, 2014
We have optimised Jira through Nginx as reverse-proxy by using few things: Nio enabled, gzip disabled on Tomcat, but enabled on Reverse proxy side, Proxy with HTTP 1.1 keep-alive, SSL offload, multiplexing SPDY https://gist.github.com/mikhailov/8562320
Nic Brough -Adaptavist-
January 8, 2012
January 7, 2012
Right, so the problem is not Jira. You may have more luck asking nginx users, as the problem is with that.
where I can find them :D waiting for the Jamie...
January 7, 2012
The base url is not that important yet - you can set it when you get Jira running.
Your Tomcat looks fine to me, so you really do need to check that Jira is running by logging on to the server and using a Browser to try localhost:8080 (or wget if there's no GUI to support a browser). If that gets you something, then you know Jira is running and you need to fix nginx settings. If it's not running there, then have a look at the application log (in fact, you should do that anyway, because Jira's startup will echo the current url to get to it into the log)
before that I used apache, and everything worked fine. after installing nginx (now apache + nginx) problems began. I understand that the problem in nginx, but I am a newbie and I can not understand the source of problem.
now in apache conf:
<VirtualHost *:85>
ServerAdmin mail
ServerName domen
DirectoryIndex index.html index.php
DocumentRoot path
AddDefaultCharset utf-8
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://localhost:8080/
ProxyPassReverse / http://localhost:8080/
ErrorLog /var/log/apache2/proj-error_log
CustomLog /var/log/apache2/proj-access_log common
</VirtualHost>
nginx works at 80 and apache in 85
JamieA
January 7, 2012
If the proxyPort and proxyHost set correctly in the Connector element in your server.xml (in tomcat)?
Is the base URL set correctly?
What URLs is the browser attempting to get for the .css files?
Im my server.xml:
<Service name="Catalina">
<Connector port="8080"
maxThreads="150"
minSpareThreads="25"
maxSpareThreads="75"
connectionTimeout="20000"
scheme="http"
proxyName="projects.dhwc.info"
proxyPort="80"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"/>
My links:
http://clip2net.com/s/1t0dr
Were is base url?
January 7, 2012
I think this is about your nginx configuration, not Jira.
Jira will be listening/publishing on whatever url and port you've configured it for (I can't tell you what the defaults for that are because you've not told us how you've deployed it - standalone, war, etc, and I think the defaults may vary slightly between versions)
"The site opened, but not displayed style" implies to me that nginx is running ok, but you've not configured it to relay/forward the Jira site. You'll need to consult the nginx docs to find out how to get it to serve up Jira.
Now my config:
server {
listen 80;
server_name my domen;
access_log /var/log/nginx/jira_access.log;
error_log /var/log/nginx/jira_error.log;
location / {
proxy_pass http://127.0.0.1:8080;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-for $remote_addr;
port_in_redirect off;
proxy_redirect http://127.0.0.1:8080/ /;
proxy_connect_timeout 300;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /var/www/nginx-default;
but it still not working...
