Setting a checkbox field with Power Automate
Kevin B. Hanson
June 28, 2021
I have an issue setting the value of a checkbox field using the value from Sharepoint via Power Automate.  I am getting the error "Specify the value for Report Required in an array"
I was wondering if anyone has had any experience setting values for checkbox fields in JIRA using Power Automate?
Thanks.
mete.c August 13, 2021
hello,
you can use HTTP request connector on power automate and set with get method :
https://(jira-instance).com/rest/api/2/issue/(jira-issue)?fields=(customfield-id)
and after you can report value on your sharepoint.
regards.
