Is it posible for the same project to have different conditions for transitions in workflow? This could enable to set the workflow configuration per product.
I do not wish to change settings for the project, but only for the product (if possible).
Hi Rene,
Yes it possible. You need to build a Custom Workflow and then add conditions.
I suppose you are using Jira Software.
Ex. Workflow: Open-In progress-Review Product A - Review Product B- Done
Create a Custom Field name Product( single selection):A,B
Youd need to create 2 separate trasition from In progress to :
a)Review Product A
b)Review Product B
Then use condition on the trasitions:
Value Field Instead of Affected Version you will put PRoduct(the field created above) and then select = and the needed value.
After this you will make the same way for B
Hi René,
what's your overall use case you're trying to accomplish and are you using Jira Server/Data center or Cloud?
Do you mean to have different conditions in a single transition?
This is possible and Jira supports ALL/ANY conditions and nested conditions by default.
Or do you want to make certain transitions only available for a specific "product"? How are the products identified? By custom field values, is this an issue type?
Best, Max
