Setting jira.title and jira.baseUrl using the JIRA REST API
Chris Kinsella
December 19, 2016
Hi
I am trying to update the baseUrl (jira.baseurl) and Title (jira.title) vias the JIRA REST API and cannot complete this task
The API guide I'm using ishttps://docs.atlassian.com/jira/REST/7.2.2/#api/2/settings and I can successfully update other settings using the same credentials (a JIRA user in the jira-administrators group)
The commandline API calls I've tried are:
curl -i -u administrator:xxxx -X PUT --data '{ "baseUrl", "https://newserver/jira" } ' -H "Content-Type=application/json"https://server/jira/rest/api/2/settings/baseUrl
curl -i -u administrator:xxxx -X PUT -d 'https://newserver/jira'https://server/jira/rest/api/2/settings/baseUrl
Could anyone please advise me on the correct API calls.
Many Thanks
Chris
Peter Geshev
December 20, 2016
Hi Chris,
You can try the following query
curl -i -u admin:admin -X PUT --data "https://newserver/jira" -H "Content-Type: application/json" https://server/jira/rest/api/2/settings/baseUrl
Peter
Justin Plute
September 28, 2019
Why just a string? That's not proper JSON, haha.
