Setting the project key suffix
Андрей Стулов March 17, 2019
For the project, I set a unique key.
I create a task key is created automatically = key + suffix
I really need the suffix (number) to be specified not automatically, but in manual mode.
I really need the suffix (number) to indicate a different number-suffix.
How can I do it?
Can I configure many flags in jira?
Max Foerster - K15t
Could you define what you mean by "configure" and "flags"? Jira itself offers various fields that can be used to manage issues in a project and globally. Labels, components, versions, different kind of custom fields etc.. But is this question connected to the first one with the issue numbers? If not and you're new to the tool and want to get familiar with it, have a look at the getting started sections in the documentation. I added the links for Jira Core Server and Jira Software Server:
  1. Getting Started with Jira Core
  2. Getting Started with Jira Software
Best, Max
Max Foerster - K15t
Hi @Андрей Стулов
sorry to break it to you but you can't influence that issues will be consecutively numbered (unless you reset the counter in the DB) when they are created. This is set in stone and so you should spend time on what workaround in issues is a viable solution for you and the users (so prefixes or suffixes within the summary, custom fields etc.).
Best, Max
ОК
