Setting up Jira 7 using SSl
Kevin Harnden
November 9, 2015
I recently setup a new JIRA 7 server and am able to access it using http;//localhost:8080
When attempting to set it up using SSL, I get a non-trusted certificate error. We already have an existing JIRA server with a trusted Certificate. I am using the same certificate from the old server.
Any help would be appreciated
Jared Dohrman [Design Industries]
November 9, 2015
Hi Kevin,
Have you followed this guide? https://confluence.atlassian.com/jira/running-jira-over-ssl-or-https-124008.html
Remember, you need any Intermediary and Root CA's in the JKS file (unless you're running a self-signed)
If you're getting a non-trusted error, have you checked to ensure that you're using the common name? (e.g. jira.domain.com)
Jared.
