Setting up Versions
Eric Nielsen
October 7, 2012
I've recently started using onDemand for both JIRA and Confluence. I've been trying to setup versions in Jira, but I can't seem to figure out how to do it. Is this feature enabled in the onDemand instances?
I click on the project name from the Projects drop down to end up on the .../browse/[KEY] page. All the documentation suggests I should see a "Versions" box on this page, that I then click "more" on to add/configure versions. However the only regions on this page are
Descriptions, Issues, and Activity Stream
I have the "Summary" tab selected. The other tab options are Issues, Popular Issues, Calendar, and Labels. None of which have anything related to Versions.
Jobin Kuruvilla [Adaptavist]
October 7, 2012
Yes, it is enabled on the onDemand instance. Are you a project administrator?
If so, go to Administration > Project where you want to add versions. Then click on the Versions tab. You can add versions there.
Eric Nielsen
October 7, 2012
Administer > Issues > Projects > Version worked.
Yes I am the project administrator. Thanks for the help.
Bob Swift
October 8, 2012
OnDemand is a bit of a pain this way. The versions tab on the project view doesn't show up until a version gets added. After that, going to the versions tab will display the Manage Versions link (if you have permission) so the next versions can be added more obviously. I usually just use addVersion to avoid all the clicking :).
Süleyman June 10, 2020
I am admin and I dont see this  path int he admin menu. (Administer > Issues > Projects > Version worked.)
Nic Brough -Adaptavist-
June 10, 2020
It has moved in the last 8 years...
Can you confirm if you are on Server, or Cloud, and if Cloud, in a classic or Next-gen project?
oo yes 8 years :)
I am using  Classic   cloud  and free plan for now.
I saw it in this menu.  Admin/Projects/ Projet Name/Project settings/versions/Create Version
October 7, 2012
Sounds like you don't have "project administrator" permissions in the projecy you are looking at. Could you check that?
