Setting up application links between Fisheye repository and Jira project
Jon Cotter
August 19, 2011
Im trying to set up an application link between a Fisheye/Crucible repository and a Jira project.
in Fisheye, when i try to create a new application link from the repository Application link screen, I get the following message:
Sorry, there are no links available when using anonymous access, check the permission configuration of the remote application.
Now I am well aware that anonymous access isnt allowed since i set it up this way, but I am not given any other option to connect. It seems that this wizard/lighbox thing should have a "back" button to let me go back to a previous step where I select authenticated vs anonymous.
Any ideas?
FeCru 2.6.1, Jira 4.3.4
Yes application links are configured
Boris Berenberg
August 22, 2012
You may be hitting: https://jira.atlassian.com/browse/JRA-27200
I would recommend that you try creating the link from within FishEye.
seb
August 21, 2011
You will be able to configure the authentication mechanisms that FishEye uses to communicate to JIRA by clicking the "configure" link after an application link has been created:
Configure
