Hello, when a create a project using a template (Share settings with an existing project) the project is created properly copying for the one I selected, but it doesn't copy the same roles (people) and I need to add them manually, is there a way that copy not only permissions and copy the same people/roles in the new project?
Thanks in advance.
Hi @Sara ,
at the moment this is the expected behaviour : roles are not copied when you create a new project with a Shared Settings. You would have to manually add them again.
There is a ticket on Atlassian side to implement this feature, you can add your vote here : https://jira.atlassian.com/browse/JRACLOUD-60335
Let me know if this helps,
--Alexis
