Show required fields forgotten in a same view
Nath April 18, 2019
In Jira Server, when the user forgets a required field in one of the tabs, he must browse through them to find the forgotten fields. Is there a way to display these fields in the current view or in a pop up, when the user has validated a first time but has forgotten one of the required fields ? The user will not have to search in all the tabs.
Thanks for your help.
Joe Pitt
Not out of the box. From an ease of use all the fields required at creation should be on the create screen close together.  In my opinion if you're breaking the create screen into tabs you're asking for information not needed, or available, at creation time and it can easily overwhelm the user creating the issue. Those additional fields should be on the edit and view screen.
Nath April 29, 2019
Is there a solution to know if a field is "setRequired" true or false ?
Thank You.
Nath
