Showing custom fields in issue navigator when searching for multiple issue types
Magnus Haglund
Is there anyway to workaround the limitation in the issue navigator that removes columns with custom fields that are not used by all issue types in the search?
(Not searching for just one issue type at a time and exporting to excel and then combine the excel documents)
Jobin Kuruvilla [Adaptavist]
September 6, 2012
For simple search, no. Advanced searching doesn't have that restriction!
Magnus Haglund
Well.. when I configure which columns are shown in the issue navigator (advanced searching) there is shown this note:
Not all the fields below are shown in the issue Navigator for each issue (eg custom fields which are only per-project and/or per-issue type)
We are using Jira v5.1.3
Magnus Haglund
And yes, I am using advanced search and it does restrict showing custom fields when the result includes several different issue types where the custom fields are only used by some of the included issue types.
September 6, 2012
Oh sorry, if you are talking about result columns, then yes. It is restricted in both cases. I thought you were talking about the fields displayed while searching.
There is no workaround to avoid it. Actyually, it is designed to work that way because it doesn't make sense to show fileds which doesn't belong in the context of the query.
Magnus Haglund
Ah, that's too bad.
Actually, it does makes sense in most cases for us. :)
Magnus Haglund
Nope, no context are used for the custom fields.
Christian Czaia [Decadis AG]
September 6, 2012
Maybe those custom fields are bound to the issue types through a context? If not they should show...
