Similar automation rule not working
john_monteith
I have an interesting issue, I have the following automation rule:
This rule performs as expected. Here is audit log of latest run:
I then have this rule which was copied from the above rule and the only thing changed was the destination status in the first step. Destination status is valid and was selected using the drop-down menu.
However, this rule does not work
Since there is nothing different about the two rules other than step 1 and that is working, I don't understand why the edit issue steps have a problem. Literally a copy of a working rule.
Bill Sheboy
February 6, 2025
Hi @john_monteith
When a rule action edits an issue, that updates the data stored in the cloud, but does not update the in-memory data for the issue in the rule.  This is by design when there are cases to observe the original data.
When you want the issue updates to be available, add the Re-fetch Issue action after an update: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Re-fetch-issue-data
However, that would not be needed for your rule if you update both fields using a single Edit Issue action.
john_monteith
Thanks Bill, as I said in my post, the rule that is "misbehaving" is a copy of a rule that works as expected, so there are zero differences other than the trigger in step 1. The audit logs show a problem in the edit issues section of one rule but not in the other and it is literally the exact same commands.
Bill Sheboy
February 6, 2025
Please show images for both of the complete Edit Issue actions.  Again, I recommend combining these into one action.
Until we see those, here are some follow-up questions:
  • Are those fields which failed custom fields that can be set manually by a person for issues, such as the trigger issue?
  • How is the issue transitioned which triggers this rule: manually by a person or by another automation rule?
  • Are there any workflow transitions which also update fields in the issue?
  • What is the scope of the rule: single-project, multiple-project, or global?
    • When the rule is other than single-scope, the rule could be using the incorrect, custom field ID internally...even if the rule was copied from another rule which appears to work.
  • Who is the rule actor: the default Automation for Jira, or some other user?
    • If the actor is a different user, does that actor have permission to edit the issue?
Like Bharat Kalia likes this
john_monteith
  1. I combined both edit issues into one action, still has the same error, here is screenshot.A05 edit issue.PNG
  2. Trigger is manual.
  3. No
  4. Single project
  5. Default Automation by Jira
Bill Sheboy
February 10, 2025
Thank you for checking with the single edit.
If there are no duplicate fields (with those names) and the fields can be edited manually from an issue view, I am unclear why those errors would appear.
I recommend working with your Jira Site Admin to submit a ticket to Atlassian Support to check.  They have access to logging / info we cannot see and so perhaps can figure this symptom out.  https://support.atlassian.com/contact/#/
Bharat Kalia
February 6, 2025
@john_monteith - Would you mind checking on the "Transition" screens for both the transitions and see if the fields you are trying to edit are present on the transition screen(for the second rule transition). Maybe that's the issue...I haven't tested this out but just my 2 cents.
Bharat
john_monteith
The transition is a valid transition:
john_monteith
There are no transition screens for any of these status changes. The issues are simply changing status
Bharat Kalia
February 6, 2025
yes @john_monteith , but can you check the transition screen? That pops up when you move to implementation. Is the field is there on that screen?
john_monteith
Bharat Kalia
February 6, 2025
Can you also provide the screenshot of the edit screen for that issue type?
john_monteith
This is the General "tab" of the edit screen, the fields to be edited are in the 2nd and 3rd tab, I have included a screenshot of the 2nd tab.
