In Slack, using the slash command `/jira`, how do I comment on an issue? I would think it would be something like `/jira PROJ-12 My comment for the issue`
Hello Chris,
Check this out, https://jirioslackapp.com/jirio-jira-slack-integration-app-slack/
Slack doesn't have a Jira issue comment option as far as iI know.
YOU DON'T NEED ANYTHING THIRD PARTY
hi @Chris Just wanted to make sure you know we also offer this functionality and a lot more with Jira Integration+
