Slow perofrmance of Jira when we use Project where we configured scripts from script runner.
We used scripts to field dependency,auto transition,permission restriction, edit restriction for one of our projects, now when we try to create or edit bug(single issue type in that project) in that project its slowing down the operation which is causing lot of trouble for us, slow performance due to scripts.
need solution for it at the earliest.
Take a look at your authentication lookups on your server, and the specific ordering. You may have a lookup (linux may be files like /etc/nsswitch.conf, /etc/resolv.conf/ and pam files in /etc/pam.d) Check your system logs for timeouts.
