Smart commits not working
Chen Hui Jing
August 26, 2015
My workflow uses Resolve as the transition from ToDo to Done. The first time I used a commit with the following message: ASW-1 #resolve Fix menu links, the commit showed up on the issue after an hour. But all subsequent commits on other issues using the same format don't show up on JIRA at all. When checking the DVCS accounts on JIRA there are no error indications on the repository though.
Felipevsw
August 27, 2015
Hi, Chen.
There was a temporary problem (~45 minutes) with Bitbucket's hooks yesterday, but it should be all working now, but if you need further assistance please open a support request at https://support.atlassian.com
Cheers
Felipe
