Soap error 4.1-1, with JIRA 4.2.4 when creating an issue with custom field (select list)
Reinhard Eder
March 21, 2012
com.atlassian.jira.rpc.exception.RemoteValidationException: {customfield_10010=Invalid value 'PROD' passed for customfield 'Deployment Environment'. Allowed values are: LOCAL [Developer Workstation], DEV [Development], TEST [QA], PRE_PROD [Pre-Production], PROD [Production], -1} : []
???? PROD is allowed value
The same thing works with JIRA 4.4 !!!!!!!!!
Also tried it with setting the ID (10...), same problem.
Reinhard Eder
March 22, 2012
Thx, this works (in 4.4.1 also setting the internal id worked)
Dieter
March 22, 2012
But if you pass the value "PROD [Production]", does that work?
